I'm on vacations time, so, here is a brief report of my 100 5s 1980 from the last 3 months:
- Thanks to the hose diagrams for carburettor's vacuum given by Sylvain, people at workshop could finally connect the system. But carburation problems has already started. Today they aren't solved, the guy at workshop is looking and fixing many hose leaks, and the car doesn't has a good cold start. Besides the engine "pulls" at 3000 rpm. And it seems to be there is a temperature problem too, because when the car is running on highway at 100 km/h, temperature ups from 90 to 95°c, ventilator doesn't stop, and when I left the higway, temperature ups a few grades more, then the ventilator takes too much time for cooling, and all the water inside the reservoir is "evaporated". There's no water leak on first sight, so I supposed it could be problems related to radiator or thermostat.
- Thanks to the help given by Hacki & Andreas, I found the small compressor for powerlock!!! Here is it:
Uploaded with ImageShack.us
Since I'm the original pitecantropus (clumsy at maximum, jaja!) when it comes to manual repairs of any kind, I'm looking for some instrumental repair shop, near to my neiborhood, for doing this. But it was glad to find this part just where they said it should be located.
- Just at beginning of carburation's jobs, the car started to "shaking". Vacuum system were not connected at that time, but readjusting of the cylinder engine cover was performed. People at workshop said that the problem were the engine mounts. Andreas helped me and finally I could buy new "motorlagers"
- I did a kind of rebuilding on front suspension. Shock absorbers, brakes, CV joints, ball joints. It wasn't what I expected.
As you people can see, car is frontally lifted. Apparently, spring coils must be changed too. So I could get new ones, and when carburation will be ok, I will change the spring coils. Hopefully, they will bring back the car's height.
Well, that's all for now, folks.
Comments, sugestions and documentation (if there is something of carburettor in english or spanish, just let me know) will be welcome.
Would you like to talk about the Pope Francisco now??? ejejejej, just joking.
Keep in touch!
Emiliano
