Audi 100 Avant Question from Denmark
Type43Henrik_DK
#1 Beitrag von Type43Henrik_DK »
Hello There !
Thanks for joining your forum. I have to write in english as my german is very bad - I hope it's OK !
Well first of all, I have a Audi 100 Avant 5E from 78 and very happy for it.
I Have owned for year now and it is driving well, but ofcause there are some things i would like to do better. I the first thing I would like to do is, paying attention to the engine/gearbox mountings. Has any one experince in changing these? Do I have to take the hole engine/gearbox out of the car ?
is it the same mountings as in the type 44 ?
Looking forward to hea from you !
Thanks
Henrik Larsen from Denmark
Zuletzt geändert von Type43Henrik_DK am 09 Feb 2007, 22:32, insgesamt 1-mal geändert.
Re: Audi 100 Avant Question from Denmark
#2 Beitrag von Andreas »
Hello Henrik,
If you change the mountings one after another one and support the engine/gearbox from underneath with a jack or something you don´t have to take the whole thing out of the car.
The rubber mountings from the 5-Cyl Type 44 are the same as in the 5-cyl Type 43.
Older Type 43 had different rubber mountings for the engine but this version isn´t available anymore. But the newer ones will also fit.
I would change the rubbers of the Aggregateträger (don´t know the english word) too.
Sorry for my not so perfect English,
Type43Henrik_DK
#3 Beitrag von Type43Henrik_DK »
Hi Andreas !
Thanks for your quick reply and sounds good that I can use type 44 mounts both engine and gearbox ?. As far as I can see and read, there sould be two engine mounts in front of the engine and two gearbox mounts ? As I have the earlier type 43 I should go for earlier type 44 - is that right ?
Have you tried this operation ?
Thanks Henrik
#4 Beitrag von Andreas »
Hi Henrik,
yes the 44 mounts do have the same parts number as the Type 43 parts: 431 399 151 D for the gearbox and 443 199 379 E for the engine.
The older engine mounts had the numbers 431 199 381 M for the left side and 431 199 382 K for the right.
For the right engine mount you should use this part: 443 199 469 C, it protects it from the heat of the exhaust.
i´ve already tried this, but on a 4-Cyl Type 43.
Type43Henrik_DK
#5 Beitrag von Type43Henrik_DK »
Hi again !
Great help and thanks alot.
So have I understood you correct:
The two ( or is it three ) gearbox mounts 431 399 151 D
And all the engine mounts left and right 443 199 379 E
or should I also use 443 199 469 C or is it an alternative ?
Would there be any difference in changing theese mounts 4 vers. 5 cyl. you think ?
Thanks again for your help !
Henrik
#6 Beitrag von Andreas »
443 199 469 C is a part which protects the (right) engine mount from the heat of the exhaust.
there are 2 gearbox mounts and 2 engine mounts.
I think there shall be no problems changing the older into the newer engine mounts. The engine support an the consoles of the body from the older Type43 do have the same parts numbers as the newer ones.
The engine mounts from the 4-Cyl ist a bit smaller than the 5-Cyl Version.
andreas
E_S
#7 Beitrag von E_S »
By the way, does anyone know if the brackeds welded to the body (the ones that carry the engine mounts) is the same on the 2.0 4-cylinder as the 5-cylinder? I know the smaller 4-cylinder uses different mounts, but the 2.0 4-cyl looks a lot like the 5-cylinder mounts..
#8 Beitrag von Andreas »
no, the 1,6l and 2,0l 4-cylinder engines do have the same mounts. Different as the 5-cylinder mounts.
