Yes, I too prefer the Cortina over the Taunus, Cortina has 'softer' lines all around. I didn't know that only 1300s were produced as 2-doors!
I managed to get it running, and it's an interesting story, I've never heard of a similar problem. After rebuilding the carburetor and put a new AC pump in, the car would start for two seconds but wouldn't run, and it was spewing fuel back through the carburetor intake. Naturally, I assumed that one valve is burnt, stuck, or broken, causing the lack of compression on one of the cylinders, which messed up the vacuum and returned fuel to the air filter. So I went to take the engine head off to get to the valves. First we removed the exhaust pipe connecting to the manifold, and I cranked it, to see what'll happen at the exhaust. What happened was that the car started right up! Upon reconnecting the exhaust, engine died. I drove it to an exhaust service (and it was VERY loud!), and the guys there found a dead rodent in the center muffler
