Hello,
I have mentioned earlier that I have a 1980 Audi 200 5T with a noisy automatic transmission. I bought a spare parts car two weeks ago that unfortunately had two litres of WATER in it’s transmission instead of transmission fluid so I had to take that car to the junk yard <img src="frown.gif" border="0">
<img src="http://www.typ43.se/Pictures/FPD/fpd_3.jpg">
Pic of the spare parts car.
I have almost given up on findning a good auto transmission for my car, but at the junk yard I found a -86 or -87 Audi 100 turbo with a manual gearbox. Is it possible to convert my Audi 200 5T type 43 automatic to a manual gearbox from a Audi 100 turbo type 44?? Can I use all the parts from a type 44? Gearbox, clutch, pedals, driveshaft’s etc?
/regards Micke from Sweden
200 5T automatic to manual gearbox
Jörg Lohrbach
Re: 200 5T automatic to manual gearbox
Hi Micke,
if you consider to undertake such a big job as to convert from auto to manual you should rather collect the workshop manual for your auto gearbox and give it fresh clutch discs, bearings and seals.
Converting to manual is a big job as you not only have to install a clutch pedal and cylinders but you need the matching gearbox supports and so on, ending to find an exhaust which will fit.
To fix the auto gearbox is not too complicated if you follow the workshop manual instructions. You will need no very special tools but some general experience, cleanliness and oversight. And a large desk to put all dismantled parts on. You must keep playing kids off otherwise you will never be able to put all the parts together once again.
I had an RB auto tranny in our '78 5E, and to have a longer axle ratio I took a 200.000 km worn out '87 RDX auto gearbox out of a type 44. It had no more forward drive, so I gave it an overhaul here in my basement, and now after five years it is still fine.
So come on, fix your gearbox yourself!
Mit freundlichen Grüßen
Jörg
---0000---
Jörg
---0000---
I have converted an '87 Audi 100 Turbo from automatic to manual. Not very much work, the most tricky was changing the whole pedal bracket thing under the dash. The transmission will bolt up to the engine (all 5-cylinders are the same), but you need a flywheel. You need to change the subframe to one from a manual car, but a type 44 subframe will fit. Use the driveshafts from a manual (remember that non-ABS driveshafts cannot be used in a ABS-equipped car) and install the shift linkage. It was, like I said, pretty easy on the type 44. The automatic exhaust should fit with the manual transmission, as the manual is a bit smaller.
Hi Micke,
we have two Audi 200 5T Automatic here in stock as a spare parts car. The problem is: we are from Bavaria (Munich), so it´s maybe too far from you. One of the cars I drove 250 km from Switzerland to Munich - the auto-gearbox worked very well. I can not promise you exactly, when we will take this gearbox out of the car, but we will...
If you are interested in please let me know.
Kind regards to Sweden,
(Gustav Mahler)
und noch ein paar 44er...
(Gustav Mahler)
