Audi 100 C2 Gear Linkage Bushing Issue
Rene147
#1 Beitrag von Rene147 »
Having an issue with a bushing in the gear linkage of a 1977 Audi 100 C2. Specifically, the bushing that fits around one of the ball joints has given up. The problem is that I can't find it anywhere.
Wondering if anyone might have an idea where this part could be sourced? The bushing's inner diameter should be 20mm and outer diameter 30mm. Apologies for the vague description — I'm not entirely sure myself what this part is called. 😊
Adding a couple of photos as well.
CarstenT.
Re: Audi 100 C2 Gear Linkage Bushing Issue
#2 Beitrag von CarstenT. »
What's your FIN?
I trinken it has to be the 431 711 221.
#3 Beitrag von WJ-Freak »
Hi René,
I just took a screenshot out of parts program.
As you can see, for the part 18, two different versions exist, for 4-speed and 5-speed transmission.
The version for 5-speed should be available at Audi tradition shop (you can find it in other shops as well):
https://audi-tradition-parts.de/de_DE/p ... ne_z011645
The one for 4-speed is difficult to find, I found it here:
https://www.amk-autoteile.de/Audi-Ersat ... :1083.html
I recommend to replace the bushings 24 as well. They are typically worn, making it also difficult to select the different gears. But also difficult to find. :cry:
Rene147
#4 Beitrag von Rene147 »
Thank you for your replies!
