2006 Audi A6 2.7 TDI
1982 Audi 100 CS 5E
1981 Audi 200 5T
1979 Audi 100 Avant CD 5E
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
1972 Hillman Hunter GLS
fine to see a RHD 200. The outer appearance seems to need some work but you don't have heavier damages concerning the body, as I assume. The screen has drawn water, hopefully the frame is not rusted.
With that mileage and only two owners the technical condition should be OK?
Keep on running ... Michael
The condition is good, but it does need some work as it has been "sleeping" since 1991!
All the electrical items work and it has a rebuilt transmission.
There is some surface rust on the roof but it is not bad. I am sending it for a full repaint later this month.
It will also need a new screen which can still be ordered with the correct colour in the UK.
1982 Audi 100 CS 5E
1981 Audi 200 5T
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
Congratulations also from my side for this great car!
It seems your goal is to build up a typ43 fleet in meteor-metallic
What options the first owner of the car ordered in ´81?
Please be careful with the rust on the roof.
This is the most critical area for rust (in my opinion) and normaly you will have a bigger problem if you have more than pickles there. The rust ist coming from inner to outer súrface. Welding is nearly impossible if you don´t have the right roofparts as spare.
Hopefully I won't need a new roof, but I will do whatever it takes to get the car back to mint condition.
The only extra option available on the RHD cars was air conditioning, everything else was included.
1982 Audi 100 CS 5E
1981 Audi 200 5T
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
The work has begun!
The roof is the biggest problem, I may have to find another which will not be easy, also the fueltank which is too rusty.
I have found some parts but not all (Warny have no more parts for the typ 43) but I will keep looking!
Aktualisierung
Die arbeit hat begonnen!
Das dach ist das größte problem, darf ich einen anderen, der leicht nicht sein wird, auch der fueltank finden müssen, der zu rostig ist.
Ich habe einige teile gefunden aber nicht alle (Warny haben Sie nein mehr teile für den typ 43) aber ich werde behalten, anzuschauen!
1982 Audi 100 CS 5E
1981 Audi 200 5T
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
1982 Audi 100 CS 5E
1981 Audi 200 5T
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
just amazing work. The turbo will be worth it, though
Q: You`ve found a new tank? And if so where?
(Sadly my type43 shares your's probs, roof and tank. I`m glad my other Audis are zinc proteded.)
Regards,
Axel
Munich
Hello Axel,
It will be worth it in the end.
Regards,
Daniel
1982 Audi 100 CS 5E
1981 Audi 200 5T
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
It is so nice, amazing and interesting to see how work is going on on your Audi 200 5T. It seems finally it found the right owner. Great to see you found a new (sun-) roof, that makes things easier. As a body maker I can let you know it was the right decision to change the roof. Otherwise the rust always will come up again (when rust took over the roof like yours).
New headlight frames, taillights, a new grille and windscreen - I am sure you will replace the headlights, too. Where did you find all the parts? Seems the Distributer Audi of Ireland still has some parts in stock …
If you’ll need a new front bumper, Audi Tradition has some of them in stock. And if you are looking for new moldings (these ones which are on the fender and the doors to protect the body), just let me know. Some of them are available here in Germany, some in the USA.
I think, you also will repaint your 16-spoke alloy rims. I just wanted to remind you that two different colors were delivered to the customers, depending on the model year. In the first model year (1980) the color was a little darker, the 1981 and 1982 Audi 200 got a brighter golden color! If you need the color codes, just let me know!
It is great you save that RHD Audi 200 5T!
Greetings from Bad Friedrichshall, which is 5 Miles away from the Audi Neckarsulm plant, where your Type 43 was assembled!
Zuletzt geändert von audi-nsu-fanatic am 27 Feb 2011, 13:32, insgesamt 1-mal geändert.
The wheels have been cleaned and will be painted "Altsilber Hell" colour code L V7Z, which I think is correct?
Regards,
Daniel
1982 Audi 100 CS 5E
1981 Audi 200 5T
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
yes, "Altsilber hell - Y V7Z" is the correct color for the 1981 to 1982 model year. I am glad you put on the original rims!
Concerning the headlights. The LHD versions are easy to find here in Germany, but I forgot you need the RHD lights ...
Anyway, I am shure they are available, because they have a standard size to replace the American sealed beam lights.
Hope to see more pics soon!
Because you bought so many expensive parts in Germany, I will buy a whiskey from Ireland next time! At the moment I just have whiskey from Scotland in my bar (Talkisker, Highland Park 18, Laphroaig, Lagavulin, Aberlour).
Stripping the front end revealed some hidden damage
So my credit card went to Germany again to Audi Tradition
1982 Audi 100 CS 5E
1981 Audi 200 5T
1973 Audi 100 GL
1973 NSU Ro80
1974 Fiat 130 Coupé
