Search for new wastegate spring. Maybe somebody know partnumber of it?
Thanx
Hello, Maic!Hacki 200 hat geschrieben:Hi,
I do not find the partnumber but I can recommend a well known tuner based very close to Ingolstadt. He was selling tuning springs for the Wastegate in different stages in the past.
I bought one few years ago for approximately 35€ in order to get my 5T with a Typ44er Wastegate back to the right level of boost pressure. Still some 0,1bar missing but I am not done so far![]()
The name of this tuner is Alfons Hohenester, you can find all details on his website http://www.hohenester-sport.de/?Motorsport
The spring was listed earlier in his web-shop but I just checked his webside and the shop is empty. If you are interested I can call the shop to figure our if teh springs are still available.
By the way: Very nice job on your 5T![]()
Greatings from southern Germany
Overpressure, arrow on first mark after 1 bar.Hacki 200 hat geschrieben:Hi,
you mean 1,2bar over pressure boost or just 0,2bar boost?
If you have too much boost than sometimes the reason is a blocked pressure pipe from the exhaust. There is a small pipe from the exhaust which delivers the pressure which actuates the valve. The early version is a one piece part which is smaller in diameter and sometimes get blocked by soot particles or damaged/cracked by the vibrations.
Or maybe the caliper in the wastegate just got stucked?
Have you checked the diaphragm?
I will call them in the next days. I need another spring anyhow for my Papamobil.
Now I have some supportive motivation to call them![]()
