Geräusche beim 200er von Mikke(Jörg)
Gunther
Globaler Moderator
Globaler Moderator
#1 Beitrag von Gunther »
Hallo Jörg
Hab heute mit nem Kfz Meister geredet,der mit diesen Fahrzeugen groß geworden ist.Der meint,daß beim Ausgleichgetriebe ein Lager Luft hat.Kam früher schon mal vor.Manchmal hilft schon ein neues Automaticöl.Wenn nicht,gibts nur zwei Möglichkeiten:heulen lassen oder richtig Geld investieren und das Getriebe überholen lassen.Könntest du das bitte Mikke ins Englische übersetzen v.lleicht hilfts
Gunther
Audi V8 3,6l nauticblau 1.90
Re: Geräusche beim 200er von Mikke(Jörg)
#2 Beitrag von WJ-Freak »
Hello MIcke,
That's just a short translation of the last posting of G.Holley:
He talked to one of his friends who worked as a foreman at a Audi garage when our cars were brand new. So his friend has a lot of experience on our cars!
He told that it seems that one bearing inside the final drive has a gap which is to big (due to wear, or a tolerance problem). From his point of view, there are two solutions: the first one is to accept the noise while driving, the second one will be to take the transmission out of the car and have a general rework, which of course is really expencive.
From my personal point of view, driving with the noisy gearbox is not a good idea, because it will destroy the gear more and more, until it even cannot been repaired.
Is there a chance to find such a gearbox (or on of the next Audi 200 turbo model, "Type 44", they fit as well) in sweden?
mikth
#3 Beitrag von mikth »
Hi and thanks for your help!
Well I changed the bearings (except the ones inside the differential) but I did not adjust the gaps in the bearings. With normal driving the noise starts with second gear but it will increase even more in third gear. If I put the gear shifter to 1 the noise will also come but only in high revs.
I know of one really rusty 1981 200 5T which has a good transmission but the owner is not sure he wants to sell the car to me cheap <img src="smile.gif" border="0"> But I am working on that.
<img src="http://www.typ43.se/Pictures/KTS/Conver ... 010017.JPG">
Changing the converter.
<img src="http://www.typ43.se/Pictures/KTS/Lagerb ... 010024.JPG">
<img src="http://www.typ43.se/Pictures/KTS/Lagerb ... 010001.JPG">
Final drive.
Thanks again!
/regards micke
Zuletzt geändert von mikth am 02 Jan 2007, 22:46, insgesamt 1-mal geändert.
#4 Beitrag von WJ-Freak »
Hello Micke,
well, regarding the pictures, I think you normally should have found the bug. But perhaps the problem is that you haven't re-adjusted the bearings and the gearwheels. I just checked my repair manual for that. Looks like a lot of work. I have never re-assembled an automatic gearbox by myself.
If you need a copy of the repair manual of the automatic gearbox (english version), please let me know. Than I'll scan it page-by-page and send it to you by email.
Regards
Jörg
mikth
#5 Beitrag von mikth »
Hi Jörg and thanks!
If you could send me the repair manual it would be perfect! (<a href="mailto:micke@typ43.se">micke@typ43.se</a>)
I think thoug that the thing for me to do is to change the entire transmission! I will continue my search for a good used one.
Thanks so much for your help!
/micke
#6 Beitrag von WJ-Freak »
OK, Micke. I'll prepare that for you. But it might take a few days.
Regards
Jörg
