Aktiver Kühlerlüfter
audi-classic
#31 Beitrag von audi-classic »
Moin,moin, sogar ich muss vieles nachfragen, obwohl ich meinen Hauptschulabschuss auf dem dritten Bildungsweg gemancht habe
Gruss Detlef, Man(n) wird nicht Erwachsen nur die Spielsachen werden teurer
tamz
#32 Beitrag von tamz »
Hello everyone.. I am Tamer, froum Turkey... I have searched this forum for a long time..I have year model 1980, Audi 100 2.0 diesel. Classic cars are not popular in my country and unfortunately there is no audi 100 or typ43 forum. I am happy that I found this forum to ask anything for my car. I am sorry I can't speak German, I wish I could but I can just speak English.. I hope this will not be a problem..
My car has similar problem. I guess it doesn't have a cooling fan. Accordingly, its engine gets hot quickly.I don't know what to do..
Thanks ;)
bdsf2003
#33 Beitrag von bdsf2003 »
Hello from Germany! If engine gets hot quickly you should check thermostat and cylinderhead / gasket. Open cooling liquid tank with running engine. Are there bubbles coming up? Problem with my car was that the electric cooling fan started with cold engine without ignition. Relay was somehow broken. So it was different problem than yours. Have a nice evening! Bjoern
Mini One D 2013
BMW X3 30d 2011
Saab 900 II turbo Cabrio 1996
tamz
#34 Beitrag von tamz »
bdsf2003 hat geschrieben:Hello from Germany! If engine gets hot quickly you should check thermostat and cylinderhead / gasket. Open cooling liquid tank with running engine. Are there bubbles coming up? Problem with my car was that the electric cooling fan started with cold engine without ignition. Relay was somehow broken. So it was different problem than yours. Have a nice evening! Bjoern
Thank you very much ! I see that the writing in top of the page " foreign friends are warmly welcome" are coming true..The problem in my car is, when I start the engine, engine temperature gets hot quickly :( In 15 minutes, temperature display shows 90C which is not normal. I will check your solution. My car is being painted right now. There is much work to make it okey :razz:
bdsf2003
#35 Beitrag von bdsf2003 »
90 degrees are not to hot i think. Is the red light burning when you drive and engine gets warm? When engine is running while car stands still it's normal that the temperature goes up to 90 degrees but the electric fan should start then.
Mini One D 2013
BMW X3 30d 2011
tamz
#36 Beitrag von tamz »
I have just taken the car..It has much work to do such as hood and painting.. by reason of its too old, I even thoght that it doesn't have a cooling fan :D
When I start the engine, It becomes 90degrees in a short time even if I don't move the car :(
